navigasyonlu müzik sistemi
Ziyaretçi · 19 · 10595
octaviaman
Süperskoda da gördüm.199 Euro fiyat çok düşük ama garanti yok iade ve değişim yok kıllandım.Var bi iş bu işin içinde ya defolu ya tamir görmüş tahminimce.Sizler de görün istedim.
http://www.superskoda.com/octavia-ii/electronics/octavia-ii-touchscreen-dvd-navigation-rns-510-alternative
Octavia II - touchscreen DVD navigation (RNS 510 alternative)
Cat. number:W2-D780SWeight of an item incl.packing:5 kgOur price:199.99 €
unitAdd to FavouriteIn stock:item is in stockDescription:
*********SALE**********
previous price 649,99eur
now for crazy 199eur !!!
price valid while stock lasts
- RNS 510 (Columbus) alternative
- better equipped unit than RNS 510 !
- DIRECT INSTALL INTO CENTER PANEL OF YOUR OCTAVIA II !!
- NO MODIFICATION NEEDED !!
- OEM Skoda navi front frame can be sent together for FREE (if required)
- DVD/DVD-R/VCD/CD/CD-R/CD-RW/DivX player
- 7 Inches touchscreen LCD
- Built-in GPS system operated by touch screen
- OS:windows CE 5.0
- Dualzone function (Listen Radio/CD while watching GPS navigation)
- Built-in bluetooth
- Coming Tel No. dispaly function
- Call out directly by touch screen
- built in microphone
- USB plug
- SD/MMC card slot
- i-POD support
- RDS receiver function
- Built-in TV tuner
- Steering wheel control function (for Octavia II with multi-functional steering wheel)
- Full-function OSD remote control
- FM/AM stereo receiver
- 4*45 Watts amplifier
- One way video input
- Two-way A/V output
- Electronic & mechanical anti-shock system
- Auto rear viewing function
- RCA line out
- SKODA GREEN BACKLIGHTED BUTTONS
- SKODA START-UP LOGO
Maps (iGO 8 Europe) are for +120EUR
GPS Features:
Map supported:
Route66,TOMTOM, IGO,DESTINATOR etc.
Operation system: Windows CE 5.0
Processor: SAMSUNG High performance processor S3C2440A-40, Max.main frequency 400MHZ.
EMS Memory :64MB SDRAM
Storage device: 128MB NAND FLASH,Support SD Card.
Display output : CVBS+S-VIDEO output. (Resolution:480*234) or simulation RGB output .
Audio output: Stereo output of CD tone.
GPS specification: Adopt SiRF STAR III 20 channel and excessive high sensitivity GPS receiving module REB-3310, Orientation sensitivity reach -159dBm, Orientation presicion<10M,Orientation time of cold boot is 42S,Orientation time of warm boot is 35S,Orientation time of hot boot is 1S.
Power specification: Connect car power DC12V,Current<500mA;Max power
Consumption:4.5W(12V/360mA),Normal power consumption 3W(12V/250mA).
System parameters:
Working voltage DC 11V~14V
Working current MAX 15A
Standby current <25 mA
Video system Automatic PAL or NTSC
Radio parameters:
FM/ AM Frequency FM:87.5MHz~108MHz; AM:522KHz~1620KHz
Tune method PLL frequency complex tune
Display method TFT Graphical User Interface OSD
Storage quantity FM radio :18 channels, AM radio: 12 channels
Search method Automatic/manual
DVD parameters:
Video output range 1+10.2Vp-p (75Ω)
Disc spec Diameter 12cm disc
Compatible disc DVD/VCD/CD/MP3/WMA/JPEG/MPEG4
Amplifier parameters:
Testing voltage 13.8 V
Maximum power output : 4×45W
Speaker impedance 8Ω (4-8Ωacceptable)
Audio parameters :
Track imbalance degree ≤2dB
Segregative degree ≥45db
Frequency response: 20Hz~20KHz(±3dB)
Volume adjustment :
Low 100HZ±7dB
Medium 1KHZ±7dB
High 10KHZ±7dB
!!!!! ABSOLUTELY NO WARRANTY !!!!!
UNIT SOLD WHERE IS/AS IS
!!!!! NO RETURNS OR CHANGE !!!!
Çevrimdışı beytullah
    • İleti: 2662
ömer abi vardır bunun altında bi çapanoğlu...
Tek dezavantaji orijinal teypteki park sensörü ekranını çalıştıramamasıymış...
Çevrimdışı vaskonx
    • İleti: 159
Anlayamadım bu fiyata.Kısa süreliğine bu fiyat diyor.Daha önce 650euro ymuş.
O bir Skoda, O bir dev, Octavia A5
:polis:
Çevrimdışı emrtkn
Bu siteye canım sıkıldıkça girer bakarım.
Gerçekten fiyatı o kadardı.
Bedava gibi birşey..
(Elektronik sistemde sorun çıkartacağını sanmıyorum)fakat çerçeve kalitesi (teybin - tuş vs) ve ses çıkışı nasıldır acaba ?
Ben şu anki orjinal ses sisteminden çok memnunum,gayet tatmin ediyor ..
Buda öylemidir acaba..
Ses çıkış özelliklerine baktığımda yeterli gibi fakat çoğu marka - modelde bu değerler tutmuyor ..
Çevrimdışı emrtkn
Tam almaya karar verdim,be bitmiş :(
octaviaman
Çevrimdışı emr
    • İleti: 22
bu navigasyonlar bizdede var vede kendi aracımdada kullanıyorum cokta memunum yani sattığım için değil önce kendi araclarıma taktım denedim sonra satışını aldım cunku müşteriyle papaz olmamak için tavsiye ediyorum güzel navigasyon bluetooth tv dvd hepsi var yani ayrıca yapımı basit ne kablo kesmesi ne bişey direk orjinal soketten teyp soketini takıyorsun okadar tv antenini ön cam direklerinden gecirip dikiz aynasının hemen oraya yapıştırıyorsun tek kusuru bi arkadaş bahsetmiş park sensörü göstermi yok
« Son Düzenleme: 23 Haziran 2009, 22:19:42 Gönderen: emr »
Çevrimdışı emrtkn
octaviaman
Alıntı yapılan: emr;20939
Emre siz kaçtan satıyorsunuz:confused:
peki siz kaça satıyorsunuz peki,a4 octi için uyumlumu?
Çevrimdışı emr
    • İleti: 22
Alıntı yapılan: octaviaman;21435
bizde 1600ytl hocam garantili dediğim gibi kesip biçmek yok orjinel soketten teyp soketini takıyorsun bitiyor vede baya fonksiyonlu yani dvd - mp3 -tv - radyo - navigasyon - usb ve ipod bağlantı yeri vede hd kart okuyucu - bluetoth gibi özellikleri var
octavia a4 için gelince onun için yok yani ama araştırırım sorarım varsa neden olmasın yani
bu benim dediğim sistem roomster - fabia - octavia vede yeni superb için uyumludur
Çevrimdışı delidolu
    • İleti: 38
Bunların a4 ler için olanından da var mı? gıcık olduğum çin yan sanayisine bile razıyım. direksiyon + bilg desteklesin kafi :)
