Plastik Şişede Su ...
Çevrimdışı emrtkn
This information is being circulated at Walter Reed Army Medical Center as well.
Bu dokuman Walter Reed Army Medical Center tarafindan da dagitilmaktadir.
Bottled water in your car is very dangerous.
Arabanizda bulunduracaginiz plastik su sisesindeki su cok tehlikelidir.
This is how Sheryl Crow got breast cancer. She was on the Ellen show and said this same exact thing.  This has been identified as the most  common cause of the high levels in breast cancer, especially in  Australia .
Plastik su siseleri Sheryl Crow'un gogus kanseri olmasinin en buyuk  nedenidir. Plastik siseler ozellikle Avustralia da yuksek sayida gorulen gogus kanseri vakalarinin en buyuk nedenidir.
A friend whose mother was recently diagnosed with breast cancer and  the Doctor told her: women should not drink bottled water that has been left in a car.
Annesi cok yakinda gogus kanseri teshisi konulan bir arkadasimiza doktor sunu soyledi. "Kadinlar arabalarda birakilmis plastik su siselerinden su icmemelidir"
The doctor said that the heat and the plastic of the bottle have  certain chemicals that can lead to breast cancer.  So please be  careful and do not drink bottled water that has been left in a car,  and, pass this on to all the women in your life.
Doktor yuksek sicaklik ve sise plastiklerindeki belli kimyasallar  gogus kanserine neden olabilir. Lutfen dikkatli olun ve arabada birakilmis plastik siselerden su icmeyin.
Lutfen bu bilgiyi etrafinizdaki butun bayanlara iletiniz.
This information is the kind we need to know and be aware and just  might save us!
Bu bilgi kesinlikle iyi bilmemiz gereken ve sakinmamiz gereken bir  tehlike ile ilgilidir. Bu bilgi yasam kurtarabilir.
The heat causes toxins from the plastic to leak into the water and  they have found these toxins in breast tissue.
Use a stainless steel canteen or a glass bottle when you can!
Yuksek sicaklik plastigin icindeki toksinleri suya ve yiyeceklerimize geciriyor ve doktorlar bu toxinleri kanserli hucrelerimizin etrafinda kolaylikla gozleyebiliyorlar.
MUMKUNSE, PASLANMAZ CELIKTEN BIR TERMOS YA DA CAMDAN YAPILMIS SISELER, KAPLAR KULLANALIM !
No plastic containers in microwave.
Mikrodalga firinlarina plastik tabak ve kutulari koymayiniz.
No water bottles in freezer.
Plastik su siselerini buzluga koymayiniz.
No plastic wrap in microwave.
Plastik tabak ortulerini (SARAN WRAP) mikrodalga firinina koymayiniz.
A dioxin chemical ca uses cancer, especially breast cancer.
Dioxin isimli kimyasal madde kansere neden olur, ozellikle gogus kanseri.
Dioxins are highly poisonous to the cells of our bodies.
Don't freeze your plastic bottles with water in them as this releases dioxins from the plastic..
Dioxin maddesi vucudumuzdaki hucreler icin bir zehirdir.
Plastik siseleri icinde su varken dondurmayiniz. Bu durumda plastik icindeki  Dioxin'i aciga cikartmaktadir.
Recently, Edward Fujimoto, Wellness Program Manager at Castle Hospital,  was on a TV program to explain this health hazard. He talked about  dioxins and how bad they are for us.
Gecen gunlerde. Edward Fujimoto, Wellness Program Manager (Castle Hospital) bir TV programinda bu saglik tehdidini acikladi. Dioxinlerin bizler icin ne kadar tehlikeli oldugu gercegini anlatti.
He said that we should not be heating our food in the microwave using plastic containers.. .
Yiyeceklerimizi mikrodalga da plastik kutular icinde isitmamamizi  istedi.
This especially applies to foods that contain fat.
Bu ozellikle icinde yag olan yiyecekler icin daha onemlidir.
He said that the combination of fat, high heat, and plastics releases  Dioxin into the food and ultimately into the cells of the body...
Yag, yuksek sicaklik ve plastiklerin bir araya geldiklerinde Dioxin  aciga cikarttiklarini ve bunun vucudumuzdaki hucrelere gectigini acikladi.
Instead, he recommends using glass, such as Corning Ware, Pyrex or ceramic containers for heating food... You get the same results, only  without the dioxin .
Plastikler yerine Cam, Pyrex, Corning Ware yada seramik den yapilmis kaplarin kullanilmasini tavsiye etti.
So such things as TV dinners, instan t ramen and soups, etc., should  be removed from the container and heated in something else. Paper isn't bad but you don't know what is in the paper. It's just safer to  use tempered glass, CorningWare, etc.
Microwave icin hazir uretilmis cabuk isitilabilen yiyecek paketlerini  baska bir kaba aktararak isitiniz. Kagit cok kotu bir malzeme degil  ama icinde ne olabilecegini hic bir zaman bilemeyiz. Pyrex, ISIcam,  Corning Ware gibi kaplari kullanmak cok daha guvenlidir.
He reminded us that a while ago some of the fast food restaurants moved away from the foam containers to paper. The dioxin problem is one of the reasons...
Bazi zincir (fast food) restoranlari yakin gecmiste plastik kutulardan  kagida gectiler. Bunun en buyuk nedeni dioxin problemidir.
Also, he pointed out that plastic wrap, such as Saran, is just as dangerous when placed over foods to be cooked in the microwave.
Ayrica, Saran wrap ismi altinda satilan tabak ve kutularin uzerine orttugumuz ince plastik film de  mikro dalga firinina girdiginde diger plastikler kadar tehlikelidir.
As the food is nuked, the high heat causes poisonous toxins to  actually melt out of the plastic wrap and drip into the food. Cover  food with a paper towel instead.
Mikrodalgada yiyecek isinlanirken yuksek sicakliklar ince plastigi eritebilir ve erimis plastk yiyeceginize karisabilir. Mikrodalga  kullanirken yiyecek kaplarinizi plastik yerine kagit havlu ile ortunuz.
This is an article that should be sent to anyone important in your life!
Bu yaziyi tum tanidiklariniz gonderiniz.
DR.Cengiz Camci MCT
Professor of Aerospace Engineering
The Pennsylvania State University_
NOT:
Anadolu’nun hemen hemen her yerinde plastik kaplar içine turşu kuruluyor. Bu turşu keskinleştikçe, plastik bidon ile yukarıda bahsedilenlerden çok daha fazla reaksiyona giriyor. Ve bir zaman sonra plastik, kağıt helva gibi kırılgan hale geliyor. Plastiğin zararlı tüm bileşenleri ise turşuya geçiyor. Bugün Anadolu’nun birçok yerinde, “nedeni anlaşılamıyor” dedikleri kanser vakalarının nedeni bu plastik kaplar.
Çevre Bakanlığı plastik ile ilgili, şirketlere bazı yaptırımlar getirmelidir. Halkı bilinçlendirmelidir.
octaviaman
Böylesine büyük bir tehlikeye işaret ettiğin için teşekkürler.Şu suni malzemelere karşı çok dikkat etmek lazım.
    • İleti: 15590
Plastik şişeleri kullanmamaya özen gösteriyorum ama nafile , heryerde karşımıza çıkıyor bu plastik şişeler..
Çevrimdışı fmaka
    • İleti: 2596
yarın arabadaki bidonları atıyorum.hemen çelik termosa transfer oluyorum.,çok teşekkrler
Çevrimdışı 06navy
  • Black Eagle
    • İleti: 1730
Sadece bayanlar için değil herkes için çok zararlı plastik şişeler. Özellikle güneş ışığına maruz kaldıklarında suyun içine bıraktıkları kimyasallar bir çok rahatsızlığa sebep oluyorlar.
Çevrimdışı ilk aşk
    • İleti: 321
    • http://www.turkiyeotoforum.com/oto/
hayatımızın her alannına plastik girmiş . eskiden ne güzel cam vardı herşeyde
Çevrimdışı ozencan43
    • İleti: 219
faydalı bilgileri tekrar hatırlamak adına
hooorrrttttt......
Çevrimdışı skodam_1985
  • Yaşayan Efsane
    • İleti: 2703
Teşekkürler :)
berfin.meb
Teşekkür ederiz.
Plastiğin çevreye ve sağlığa zararları bilindiği halde sağlıklı olan camdan daha çok tercih ediliyor ne yazık ki.
İçme suyu cam şişede yada  cam sürahide bile olsa güneş ışınları suya zarar verir.
Çevrimdışı Selman
  • Yeni Detaycı
    • İleti: 7
Çevrimdışı emrtkn
Alıntı yapılan: berfin.meb;214585
Teşekkür ederiz.
Alıntı yapılan: Selman;214612
Teşekkürler çok faydalı bilgiler.
Askere gitmeden önce açmıştım konuyu.
Vay be! dedim içimden. :)
Anılarım depreşti bir an :)
