Desenli stop karartma
lrfan · 36 · 12299
    • İleti: 30185
Boyanmış hali beni feci dürtüklüyor  :)
Kaynak Briskoda
[quote name='jonny boy' timestamp='1343226752' post='2875179']
Thanks to Freddie (Confide) for sharing the secrets and pattern for this job. Been looking forward to changing them as I've hated the colour from new.
First remove the lights and clean them thoroughly with Isopropanol (or equivalent)
Then flat them down with 2000 grade wet & dry paper and they should look cloudy like this.
Then using quality masking tape such as 3M (do not use cheap stuff) tape the area you want to be seen.
I have done a indicator & brake light test already, so the following instructions do not obliterate the colour at all. All lights are easily visible day and night. I'll get some night shots done soon.
I used a precision craft knife for the 'corners' or any trimming. Just take your time and don't press hard.
Remember, the edges MUST be completely flat with no wrinkles etc. The finished edge will depend on this, so take note !
Next apply the tint spray in smooth left to right strokes. Don't be tempted to rush this, just one coat at a time (I used 6 in total for this effect) and leave 10 minutes between coats. This is important, don't rush application or it'll run.
Finally, peel the masking tape away carefully and slowly. If you had patience and smoothed the edges along with the decent masking tape, you'll have a nice neat edge.
When these coats are dry, time to laquer the entire lens. I used 3 coats, again, wait for each one to dry !
Here's the fitted lenses. They are finished with 2500 grade wet & dry paper, then polished with decent polish. Sorted
[/quote]
Çevrimdışı etms
  • Platonik ST Üyesi
    • İleti: 596
Boya çok kalın tabaka oluşturmuş, filmle yapılsa daha hoş durabilir bence. :)
Çevrimdışı Suleyman
    • İleti: 1621
    • İleti: 30185
Alıntı yapılan: etms;425267
Zımpara yapmış son aşamada, zımpara payı niyetine  :)
Alıntı yapılan: Suleyman;425268
Beyaz arabayada ne yakışır ama...
Aldım gazı  :)
Çevrimdışı dynia
    • İleti: 715
bekleyin 1-2 güne irfan abi paylaşımını yapar bizlere :)
    • İleti: 30185
Alıntı yapılan: dynia;425271
Kasımda muayene var, onu beklerim belki :)
Ya da komşunun stoplarını ödünç alırım giderken  :++:
Çevrimdışı dynia
    • İleti: 715
Alıntı yapılan: lrfan;425273
az daha zorlarsan bi f-14 motoru bağlıcan abi arabaya :)
Çevrimdışı GÖKHAN06
    • İleti: 626
Ben komple kırmızı yapmıştım araba siyah olunca yakıştı ama geri vitese takınca kırmızı yanıyor :) Ne yapsam diye düşünüyordum, hızır gibisin abi :) Bunu octiye uyarlamak lazım.
Çevrimdışı eyskoda
    • İleti: 116
Biraz abartı duruyor gibi, bir süre sonra gözleri yorar..
Çevrimdışı 06navy
  • Black Eagle
    • İleti: 1730
Çok güzel görünüyor, ben de fabia'nın stopları boyamıştım, sonradan keşke daha kalın boya atsaydım dedim, polisaj yapınca daha güzel oluyor ama ince olursa boya 1-2 polisajdan sonra boya gitmeye başlıyor.
Çevrimdışı emreozukan
    • İleti: 127
Bu olayı farlara uygulanan cam filmiyle uygulasak, burdaki bantla maskelenen yerleri filmde kesip çıkartsak aynı görüntüyü elde edemezmiyiz acaba ? , hemde muayenede sıkıntı olmamış olur muayene zamanı hemen filmi sökebiliriz.
Benim konuyu bekleyin abi. Hepinizi galyana getiricem ben :)
