"Permanently Disable Start-Stop
Available with VCP (Vag Can Pro) as an OCF (One Click Function)
Tested on 2014.5MY cars and works with VCDS as below
· Go to Module 19 (Can Gateway)
· Adaption
· Go to Kanaal: Start_stop_voltage_limit
· change to 12.1V ( standaard is 7.6V)
The Start-Stop will show as disabled because the energy requirement from the car is too high, which is not an error but a valid reason for SS to be disabled."
Himm bu olay tamamen iptal ediyor ss i.
