Octavia Vag-Com Kodlama
-Öncelikle aşağıdaki linkteki konuyu okuyun lütfen:
http://www.skodaturkey.com/showthread.php?t=28734
*Octavia(A7 kasa) Kodlama Listesi)
Not: Kodlama listesi www.stemei.de sitesinden alınmıştır. Kodlamalar sonucunda ortaya çıkabilecek herhangi bir sorunda sorumluluk size aittir.
1.Sis Lambalarını Köşe Dönüş Farı Gibi Kullanmak:
In the network control unit gives you the option when Skoda Octavia III 5E the fog lights (NSW) to activate in addition as a cornering light function. When active, the respective low beam Fog lights is thus driven at correspondingly steering, thus ensuring additional illumination when turning.
The following code is to be applied:
1. Select STG 09 (vehicle power)
2. STG Access Permission -> Function 16
3. Enter unlock code 31347
4. STG adjustment -> function 10
5. Select channel (5) Leuchte12NL LB45 Light Function B12
6. Adjust Value on cornering left
7. Select channel (5) Leuchte13NL RB5 light function B13
8. Adjust Value on cornering right
2. Köşe Dönüş Farının Aktif Olacağı Hızı Ayarlama:
In the network control unit gives you the option when Skoda Octavia III 5E the rate thresholds for the switching on of the fog lights on Abbiegelichtes (NSW) adapt. Unless you have the Abbieglicht enabled, so you can adjust the speed values ​​still want according to your. By default, the cornering light up to 32 km / h is activated, if you can modify the entries corr. Hence eg to 50 km / h effected activation.
5. Channel (3) Select a static cornering light lower speed threshold
6. Corresponding value adjust default: 0 km / h Note: If the value of the statement Abbieglicht is thus deactivated and activated until the set speed acc in the state.
3. Akü Durumunu Sorgulama:
In on-board computer or in the multifunction display of the instrument cluster gives you the option of the Seat Leon 5F to display the status of the battery.
The following procedure shall apply:
1. Press trip odometer button / Trip button (0.0 / SET) and hold
2. Release the button once the display battery status lights
Battery indicator is displayed
4. Sağ Dikiz Aynanın Aşağı İnmesi:
In passenger door control unit gives you the option when Skoda Octavia III 5E to activate the passenger-side mirror lowering. Thus is lowered automatically when reverse gear is selected and the mirror passenger side mirror of the passenger side.
1. Select STG 52 (Türelektr. Beifahr.)
2. STG Lange Coding -> Function 07
3. Byte 04
4. Enable Bit 2
5. Enable Bit 3
6. Select STG 09 (vehicle power)
7. STG Access Permission -> Function 16
8. Enter unlock code 31347
9. STG adjustment -> function 10
10. Select (15) Access Control 2-drawdown at Rueckwaertsfahrt
11. Value to active (active) set to disable Display menu item in the radio / navigation system, so you are even able in future the function to activate or: additionally possible
12. Select (20) Access Control 2 Menu Control drawdown
13. Put emphasis on active (active)
5. Yokuş Kalkış Asistanının Süresini Değiştirme:
In the control unit of the electronic brake system gives you the option when Skoda Octavia III 5E adapt the hill start assistant. Thus you can customize the startup behavior accordingly. Depending on setting Set the brake is thus kept shorter or longer and thus facilitates starting behavior, depending on your needs.
1. Select STG 03 (brake electronics)
2. STG adjustment -> function 10
3. Select Berganfahrassistent
4. value corresponding to customize default: normal options: early, normal, late
6. Amerikan Park:
In the central electrics You have the option at the Skoda Octavia III 5E to let the front direction indicators mitleuchten dimmed (so-called. US light function). Depending on the degree of dimming is set, the indicators are therefore also activated when stand and low beam. When activated, daytime running lights (eg with a deactivated light sensor or if it is bright in the day) are not mitgedimmt the indicators, a combination of the US status light and daytime running light US is of course also possible.
3. Enter access code 31347
5. Channel (9) 0 BLK light fitting VL B36 Light Function D 0 Select (Blinker Front Left)
6. Generally adjust value on parking lights
7. Channel (10) 0 BLK light fitting VL B36-dimming select CD 0
8. Adjust Value accordingly (dimming level in percent; Recommendation value: 30 (30%))
9. Channel (9) -Leuchte1BLK VRB20 light function D 1 Select (Indicator front right)
10. Generally adjust value on parking lights
11. Select channel (10) -Leuchte1BLK VRB20-dimming CD 1
12. Adjust Value accordingly (dimming level in percent)
İlave olarak:
1. Channel (12) -Leuchte0BLK VL-B36 Lichfunktion E Select 0
2. Adjust Value Blink left dark phase
3. 0 Select channel (15) -Leuchte0BLK VL B36 dimming Direction EF
4. Adjust value to minimize
5. Channel (12) -Leuchte1BLK VRB20 Light Function E 1 Select
6. Adjust Value Blink right dark phase
7. Select 1 channel (15) -Leuchte1BLK VRB20 dimming Direction EF
8. Adjust value to minimize
7. Kalan Yakıtın Litre Olarak Yol Bilgisayarında Gösterilmesi:
In control of Gert panel (instrument cluster) you have the option at the Skoda Octavia III 5E enable the representation of Nachtankmenge in the MFA (Multi Function Display) or the onboard computer. The new menu item is then Nachtankmenge future shown in liters.
1. Select STG 17 (switchboard)
3. Bye 10
4. Enable Bit 4
8. Açılış Logosunu Değiştirme:
In control of Gert panel (instrument cluster) you have the option at the Skoda Octavia III 5E the start logo / Welcome logo on V / RS adapt.
3. Select channel screen display
4. worth adjust accordingly
§ Variant 1 Skoda Logo
§ Varinate 2 Skoda Logo
§ Variant 3 Skoda V / RS Logo
9. Fren Disklerinin Kurutulma Seviyesinin Ayarlanması:
In braking or ABS control unit gives you the option when Skoda Octavia III 5E adjust the intensity of the brake discs drying. If your car tend to squeak if you have turned off these for example in rainy weather, can the annoying dry the disc brakes can be reduced or even completely disabled scrape or squeak no longer have.
3. Select channel discs drying
4. Value adjust accordingly choices: not activated, weak, medium, strong Skoda Octavia III 5E and 5F Seat Leon factory setting status: weak <- Recommendation
10. Coming Home/Leaving Home Özelliğinin Gündüz Farları Vasıtasıyla
Yapılması:
In the network control unit gives you the option when Skoda Octavia III 5E and RS the Coming Home (CH) and Leaving Home (LH) adapt function so that only the daytime running lights are activated. The low beam (Xenon) is therefore deactivated after adjustment.
5. (8) -Leuchte6ABL LC5-light function C6
6. Check value: Coming Home and Leaving Home acti
7. (10) -Leuchte6ABL LC5-dimming 6 Select CD
8. Adjust value to 0
9. (11) -Leuchte6ABL LC5 dimming Direction CD 6 Select
10. Adjust value to minimize
11. (8) -Leuchte7ABL RB1-light function C7
12. Check value: Coming Home and Leaving Home active
13. (10) -Leuchte7ABL RB1-dimming 7 CD Select
14. Adjust value to 0
15. (11) -Leuchte7ABL RB1 Dimming Direction CD 7 Select
16. Adjust value to minimize
11. Coming Home/Leaving Home Özelliğinin Sis Farları Vasıtasıyla Yapılması:
Coming Home (CH) and Leaving Home (LH) to place function on the fog lights. Thus, in addition to the low beam activated (via LED or halogen headlamps) fog lights extra.
5. (4) Comfort Lighting Coming Home Select Lights
6. Emphasis on light fog anpassen default value: low beam
Additionally possible: Deactivation of the low beam, thus the (LED) daytime running lights and the fog lights are only activated
5. Select (8) Leuchte6ABL LC5-light function C6
6. Adjust value on inactive
7. Select (8) Leuchte7ABL RB1-light function C7
8. Adjust value on inactive
12. Araç Açılıp Kapanırken Kornanın Çalması:
In the network control unit gives you the option when Skoda Octavia III 5E to acknowledge the (so-called. US setting) of the lock and unlock greatly expand the function of the DWA +. When locking and unlocking of the vehicle is thus output from the DWA + hear a confirmation beep.
5. Select Unlock (1) feedback signals-Acoustic feedback
6. Adjust value to yes
7. Select (2) lock feedback signals-Acoustic feedback
8. Adjust value to yes
9. (8) -Rückmeldungssignale-Acoustic feedback globally
10. Importance to actively adjust If desired, the DWA can in the menu system Acknowledge be independently activated and deactivated via the corresponding menu item:
11. (7) -Rückmeldungssignale menu control acoustic feedback
12 Importance to actively adjust If desired, the duration of the acoustic feedback can be shortened:
13. (3) -Rückmeldungssignale-time of acoustic feedback from the Simple Horn
14. Adjust Value briefly
13. Bolaro Ekranda Dijital Hızın Gösterilmesi:
In Infotainment control unit gives you the option to activate the driving school mode in the new Skoda Octavia III 5E. Thus, the display shows the speedometer is digital, and represented the blinker control. Representation possible at Amundsen and Bolero
1. Select STG 5F (infotainment)
3. Select vehicle function list CAN Driving School - channel (11)
4. Adjust value on available
5. Channel (171) - Vehicle Menu operation - Select menu_display_driving_school
6. Set value to enabled
7. Channel (171) - Vehicle Menu operation - Select menu_display_driving_school_over_threshold_high
8. Set value to enabled
14. Emniyet Kemeri Uyarısı:
In the dash panel insert (KI) gives you the option when Skoda Octavia III 5E deactivate the seat belt reminders. The visual warning symbol in the instrument cluster as well as the acoustic sound is thus turned off.
1. Select STG 17 (dash panel insert)
3. Select Disable channel belt warning
4. Change to "yes" (default value: no), alternatively also possible:
5. STG Lange Coding -> Function 07
6. Byte 0
7. Disable Byte 2-4
15. Klima Fan Hızının "Auto" Modda da Gösterilmesi
In the climate control unit gives you the option when Skoda Octavia III 5E enable the display of fan speed in AUTO mode. Once activated, the current fan speed thus is shown in AUTO mode using the LED display. (By default, the LED display appears only with manual setting of the fan speed)
1. STG £ 08 (Air)
3. Byte 11
4. Bit 6 - Activate Blower Status Display in AUTO mode active
16. Tek Dokunuşla Sinyal Sayısını Değiştirme:
In the network control unit gives you the option when Skoda Octavia III 5E the Komfortblinker cycle adapt. Depending on the desired setting, the behavior of the blinker can acc. To be changed. By default, in the button 3 times blinking, in the example, this is increased to 5 cycles turn signals.
5. (2) Turn signal control comfort flashing flashing cycles Select
6. Value adjust accordingly as desired default value: 3
17. Yol Bilgisayarında Kronometrenin Aktifleştirlmesi(?)
In the dash panel insert (KI) gives you the option when Skoda Octavia III 5E enable the lap timer. In the MFA (Multi Function Display) can so the new menu level selected lap timer and lap counter are serviced as required.
3. Byte 1
4. Enable Bit 3
18. Plakalık için Led Lamba Takıldığında Arıza Vermemesi için Yapılacak Kodlama.
In the network control unit gives you the option when Skoda Octavia unlock III 5E retrofit LED license plate lights. Thus, no error message appears more in the instrument cluster (dash panel insert).
5. (1) -Leuchte25KZL HA59-load type 25 Select
6. Adjust general LED - value at 43
7. (6) -Leuchte25KZL HA59-dimming AB 25 Select
8. Adjust value to 127
19. "Rain Close”(Yağmur yağdığında camların ve açılır tavanın otomatik kapanması) Özelliğinin Açılması:
In the network control unit gives you the option when Skoda Octavia III 5E to activate the function of closure rain. The windows and the panoramic roof are In verbautem rain sensor Thus, in a sealed vehicle and activated rain sensor automatically closed. The operation can be enabled or disabled as the CAR Menu when the acc. Entry is activated.
5. (14) Select Access Control 2-rain Close
6. Adjust Value on permanently
7. 26) Access Control 2 Menu Control Select rain Close
8. Adjust Value on active
9. Select STG 09 (vehicle power)
10. Select RLS (rain and light sensor) - STG
11. Byte 0
12. Enable Bit 1
13. Enable Bit 2
20. Koltuk Isıtıcnın Çalışma Seviyesinin Hafızaya Alınması
a III 5E storing the last set level seats to activate. Thus, after restarting the vehicle, the predetermined level is automatically reset.
1. STG £ 08 (Air)
3. Select channel storage seat heating stage driver
4. Adjust value to active (default value: inactive)
5. Select channel storage of the seat heating level passenger
6. Adjust value to active (default value: inactive)
21. Far Yıkama Sisteminin Çalışma Sıklığını Değiştirme:
In the network control unit gives you the option when Skoda Octavia III 5E to increase the activation interval of the headlight cleaning system (SWRA). Thus, the front headlamp washing less often driven and thus saving cleaning water.
5. Select (1) Windshield Wiper-Number of confirmations front washer per SRA activation
6. Value adjust accordingly as desired default value: 5
22. Far Yıkama Sisteminin Devreye Girme Süresini Değiştirme:
In the network control unit gives you the option when Skoda Octavia III 5E to extend the delay time for Anpsrechen the headlamp cleaning system. Thus, the front headlamp washing is later driven and thus saving cleaning water.
5. (2) Select a windshield wiper-SRA delay time
6. Adjust Value accordingly as desired default value: 0 ms Example value: 1500 ms
23. Stop Lambalarını Gündüz farı Gibi Çalıştırmak:
In the network control unit you have the possibility in the new Skoda Octavia III 5E mitzuschalten the tail lights as sidelights with active (LED) daytime running lights. Is brightness in the daytime running lights of the headlights active, the tail lights are switched thus additionally.
5. Channel (6) - Daytime Running Lights - daytime running lights activated additionally select standlight
6. Put emphasis on active
Alternatively, if possible, you want to only mitleuchten the taillights and do not wish that the sidelights is also active (therefore no identification of the active status light on the light switch)
5. Select Leuchte23SL HLC10 Light Function D23 - channel (9)
6. Put emphasis on daytime running lights
7. Select Leuchte24SL HRA65 Light Function D24 - channel (9)
8. Put emphasis on daytime running lights
9. Select Leuchte26NSL LA72 Light Function D26 - channel (9)
10. Put emphasis on daytime running lights
11. Select Leuchte27NSL RC6 Light Function D27 - channel (9)
12. Put emphasis on daytime running lights
24. Gündüz Farlarını Devreden Çıkarmak:
In the network control unit gives you the option III 5E unlock the ability to deactivate the daytime running lights on the CAR menu in the new Skoda Octavia. After coding, the daytime running lights is listed in Car Menu in the category of light and can be automatically shuts down / turned on.
5. Select channel (2) daytime running daytime running light activation by BAP or Operating sequence possible
25. Kadran Selamlama
In dash panel insert gives you the option when Skoda Octavia III 5E / activate a link test / pointer Wipe the staging. With ignition on so all pointers go back in KI briefly stop and return to the start position.
2. STG coding -> function 10
3. Byte 1
4. Enable Bit 0
Çevrimdışı METŠAHİN
  • O C T A V I A
    • İleti: 1359
ender bey güzel payşaım için teşekkürler
donanımsal eksiklikler dışında (far yıkama yağmur sensörü gibi) ambition modelin desteklemediği seçenekleri biliyormusunuz ?
Alıntı yapılan: METŠAHİN;538709
O konuda net bilgim yok; ancak nadiren de olsa bir arçta çalışmayan kodlama başka bir araçta çalışabiliyor. Bu nedenle kodlamaları tek tek denemek daha iyi olur kanaatindeyim.
Çevrimdışı ELYASA
    • İleti: 97
Ender bey güzel bir anlatım olmuş tşkler.
Birde kodlama yapmak için kablo almak istiyorum bunu nereden temin edebilirim?
Alıntı yapılan: classi;539179
Alıntı yapılan: enoktakenokta;538717
Buradan ya da yurtdışından alabilirsiniz. Sahibinden'de falan kopya kablolar 130-TL civarı. Ben bugün 15.7 sürüm kopya kablo sipariş ettim aliexpress'ten 27 dolara. Aşağıda linkini veriyorum:
Ender Abi verdiğin link ölmüş.Aklıma takılan sey senin arac süper b acaba octavialar için vag-com kablosunun sürümü fark eder mi.Arkadas bende 12'li bişey demişti kablosuna istersen vereyim dedi de daha beter bozmaktan korkuyorum aracı
Şimdi baktım ben de; dediğin gibi link ölmüş. Diğer satıcıların linklerini de ekledim.
Araç olarak fark etmiyor, benim mevcut kablom 11... sürümlü bir kablo ve bu kablo yeni araçları kodlayamıyor. Mümkün mertebe en güncel sürüme sahip olmak daha iyi; şu anki en güncel sürüm de 15.7. Aracının model yılına bağlı olarak senin aracın 12.2.3 sürüm kablo ile de kodlanabilir. İstersen önce onunla bir dene, kodlayamazsan yeni sürüm sipariş edersin.
Ender çok gzl konu olmuş,
Forumda var gerçi ama VCDS kodunu da paylaşabilir misin? Şu sinyalde ve dörtlülerde LEd ve flaşörlerin değişerek yanması olayı
Alıntı yapılan: viperking;540243
Kodlanan bir Octavia'nın videosunun da bulunduğu linki aşağıda veriyorum:
http://www.golftutkusu.com/vag-kablosu-ile-aktive-edilebilen-ozellikler/22-u-ledli-bi-xenon-ile-sinyal-farinin-cakarli-yanmasi/
Çevrimdışı dervişbey
    • İleti: 323
    • https://www.drive.net/r/skoda/1303477/
Alıntı yapılan: enoktakenokta;540270
https://www.youtube.com/watch?v=DgBh_U4zglA
https://www.youtube.com/watch?v=Hnk_CcfCysQ
Orhan Abi ile beraber benim aracın kodlamısını yapmıştık.
İlk video Samsun'daki bir buluşmamızdan..
Yardımcı olabileceğim bir şey varsa yardımcı olmaya çalışırım:ok:
« Son Düzenleme: 06 Kasım 2015, 15:11:50 Gönderen: dervişbey »
Çevrimdışı CursetH
    • İleti: 19
Üstadım ben bu Amerikan park olayının gündüz farı ile yanması için Bursa'da kodlattım ancak sağ far sol fara göre çok sönük kaldı halbuki değerlerin ikiside aynı normal dörtlüleri yakınca aynı derecede yanıyor fakat parkları sürekli moda alınca sönük duruyor sağ far çözemedik acaba kablo sürümünden olabilir mi ?
Çevrimdışı resul_100
    • İleti: 163
Ankara buluşmasına gelmedim Ankarada bu işi beraber yapabileceğimiz arkadaş var mı
Çevrimdışı mhaktanir
    • İleti: 166
Program macbook ile kullanılmıyor. Sinirim bozuldu.
Çevrimdışı mehmetniyazi61
    • İleti: 578
Alıntı yapılan: mhaktanir;548862
macbook' a bootcamp ile vindows kurarak yapabilirsiniz.
    • İleti: 166
Windowsa gıcığım bu yüzden de bootcamp kullanmak istemiyorum. Ama Erzurum'da bulamazsam yapan kurup (tabi önce programı satın alıp) öğreneceğim bu işi.
Çevrimdışı cnrndm
    • İleti: 247
Alıntı yapılan: dervişbey;540913
sinyallerin gündüz ledleriyle çakarlı yanmasının kodunu paylaşabilirmisiniz. Ayrıca arka stopları da aynı şekilde yapabiliyormuyuz. Bilginiz var mı? Ender elektronikte kodlama yaptırdım ancak çakarlı yanma kodu yoktu kendisinde yada başından salladı beni
