Rapid Vag Com Kodlama
Not: Kodlama listesi www.stemei.de sitesinden alınmıştır. Kodlamalar sonucunda ortaya çıkabilecek herhangi bir sorunda sorumluluk size aittir. Lütfen öncelikle aşağıdaki linkteki konuyu okuyun:
http://www.skodaturkey.com/showthread.php?t=28734
*Rapid Kodlama Listesi:
1. Emniyet Kemeri Uyarısı:
In the dash panel insert (KI) gives you the option when Skoda Rapid NH deactivate the seat belt reminders. The visual warning symbol in the instrument cluster as well as the acoustic sound is thus turned off.
The following code is to be applied:
1. Select STG 17 (dash panel insert)
2. STG Lange Coding -> Function 07
3. Byte 1
4. Disable Bit 1
2. 15 km./saat Hıza Ulaşınca kapıların Otomatik Kilitlenmesi:
In the network control unit gives you the option when Skoda Rapid NH encode the auto-lock function. The vehicle locks / includes / locked thus at a speed from 15km / h automatically all the doors.
1. Select STG 09 (vehicle power)
3. Byte 0
4. Enable Bit 4
3. Araç Kapılarının Otomatik Kilitlenmesi/Kilit Açılması:
In the network control unit gives you the option when Skoda Rapid NH encode the Auto Unlock function. If the Autolock feature has been enabled on the vehicle, so the vehicle unlocks automatically after encoding as soon as you turn off the ignition / engine and remove the ignition key.
3. Byte 0
4. Enable Bit 3
4. Bluetooth Bağlantısı Sağlandığındaki Onaylama Sesini İptal Etmek:
In the telephone control unit gives you the option when Skoda Rapdi NH deactivate the confirmation tone for successful Bluetooth connection
1. Select STG 77 (phone)
2. STG adjustment -> function 10
3. Select channel Bluetooth acknowledgment
4. Provide value from
5. Fren Yardımcısının Derecesinin Ayarlanması(Normal/Hassas/Spor)
In the control unit of the electronic brake system you have the option of the Skoda Rapid NH adjust the hydraulic brake assistant. Depending on the desired braking performance sporting or sensitive (soft) can be adjusted.
1. Select STG 03 (brake)
3. Channel Hydraulic Brake Assist Select
4. Corresponding value adjust factory delivery: normal early (sensitive): brake assist is
amplified late (sport): brake assistance is reduced
6. Fren Disklerinin Kurutulma Seviyesinin Ayarlanması:
In the control unit of the electronic brake system you have the option of the Skoda Rapid NH adjust the brake discs drying. If your brakes squeal can through the change in the thickness can be achieved against an effect that should prevent squeaking.
3. Select channel discs drying
4. Corresponding value adjust factory delivery: Level 2 (medium) level 1 (weak): significant reduction in noise when brakes screeching as by the reduced brake pressure, the drying is slower Stage 3 (severe): reinforced Abdrocknung; characterized squeak stronger
7. Araç Kilitlendiğinde/Açıldığında Korna Çalması:
In the central electrics You have the option at the Skoda Rapid NH DWA acknowledge (alarm system) when unlocking and locking the vehicle with the horn (so-called US -. Style)
3. Byte 5
4. Enable Bit 1
5. Enable Bit
8. Tek Tuşla Sinyal Sayısının 1’e Düşürülmesi:
In the network control unit gives you the option when Skoda Rapid NH disable the so-called convenience turn signal (motorway flashing). After the adjustment is thus in turn signals stop only 1x blinking.
3. Byte 12
4. Disable Bit 5
9. Tek Tuşla Sinyal Sayısının Değiştirilmesi:
In the network control unit gives you the option when Skoda Rapid NH adjust the Komfortblinker cycle. You can increase or decrease the number of displayed direction change (default value 3).
3. Channel 43
4. Adjust Value accordingly
10. Arka Sileceğin Otomatik Çalışmasının İptal Edilmesi:
In the network control unit gives you the option when Skoda Rapid NH deactivate the Comfort Wipe the rear window wiper. If activated on the light and rain sensor or the set time Wipe the front wiper be turned on, when thus inserting the rear wiper no longer automatically activated. Contamination of the discs is therefore excluded.
3. Byte 14
4. Disable Bit 3
11. Direksion Yardımcısının Seviyesini Ayarlamak:
In the control device of the power steering gives you the option when Skoda Rapid NH adjust the characteristic of the steering assist. Depending on the set value is either the steering firmer (dynamic) or smoother (comfort).
1. STG £ 44 (steering)
3. Select channel characteristics of the steering assistance
4. Value adjust accordingly leave the factory: Default comfort: steering is smoother / more comfortable Automatic: Steering unchanged Default dynamics: steering is sluggish / sporting
12. Far Yıkama Tüketiminin Ayarlanması:
In the network control unit you have to adapt the possibility of the Skoda Rapid NH triggering time of the SRA (headlight cleaning system). Depending on the setting of the value of the system is therefore no longer so often raised, and reduces the consumption accordingly.
3. Select channel 42
13. Anahtarı Kontağa Takmadığınız Halde Kornanın Çalışması:
In the network control unit gives you the option when Skoda Rapid NH the horn of the vehicle set so that it can also be activated with the ignition off / operated.
3. Byte 17
4. Activate horn with terminal 15 inactive - Bit 3
14. Yakıt İbresinin kalibrasyonu(Yol bilgisayarı ile depo hesabınız farklıysa)
In the instrument cluster control unit gives you the option when Skoda Rapid NH adjust the consumption indicator. If you deviate in the average fuel consumption displayed in the instrument cluster (versus fuel receipt) If you want to perform an adjustment in percentages
1. Select STG 17 (Schlattafel)
3. Select channel display correction consumption and range
4. Value adjust accordingly The base value is 100: Set in increments of 1%, the respective maximum values ​​is 85 (%) and 115 (%).
Rapid NH3 VAG-VCDS___
KADRAN SELAMLAMA, LAPTİMER-Tur Zamanlayıcısı, EK YAKIT Miktarı.
1. 17-Instruments (J285)
2. Coding-07
3. Long Coding Helper
Byte 1
Bit 0 - Kadran selamlama ile ilgili seçenek active edilecek.
Bit 3 - Lap Timer active edilecek.
Byte 10, Bit 4=1 yapılacak. – Ek yakıt miktarı ile ilgili bit active edilecek.
Başlangıç Logosunu (VRS) Değiştirme. *****Bolero ekranda.*****
1. 5F-Information Electr. (J794)
2. Coding-07 ---> Byte 18, Bit-0 aktive.
Araç kilitlendiğinde veya açıldığında *SESLİ ONAY* vermesi.
1. 09-Cent. Elect.
2. Security Access-16 > Key 31347
3. Adaptation-10
Ch: IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking
adapted to=> Decelerate
Ch: IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln
adapted to=> active
Ch: IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global
adapted to=> active
Ch: IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn
adapted to=> active
Ch: IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln
adapted to=> active
Ch: IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn
adapted to=> kurz
Ch: IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung
adapted to=> active
Ch: IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte
adapted to=> not active
Ch: IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen
adapted to=> active
Ch: IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl
adapted to=> active
Ch: IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl
adapted to=> active
Araç kilitlendiğinde *ALARM* aktifleştirme.
1. 09-Cent. Elect.
2. Coding-07
Byte 12 Bit-0=1 yapılacak,
4. Security Access-16 > Key 31347
5. Adaptation-10
Ch: IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn
adapted to=> active
Ch: IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung
adapted to=> Stored value immidiat_driver_door_contact_thatcham
Ch: IDE04928-ENG115812-Anti-theft device-DWA Camper Modus
adapted to=> active
adapted to=> active
adapted to=> active
Not: Bu kodlama yapildiktan sonra aktif olmasi için kapılarını kilitledikten sonra 1 dakika beklemelisiniz.
Bu kodlamanin calisma mantığı şu , hırsız camı kırdı ve kapınızı içerden açtığı anda araba korna çalmaya başlıyor ve dörtlü flaşör yakıyor siz uzaktan kumanda ile kapi acma tuşuna basmadığınız sürece çalmaya devam ediyor.
Orjinal alarm sistemi biraz farklı onda iç denetim sensörüde devrede oluyor.
Kumandadan cam AÇMA/KAPAMA.
1. 09-Cent. Elect.
3. Adaptation-10
Ch: IDE08542-IDE02021-Access control 2-Comfort closing   adapted to=> "active"
Ch: IDE08542-IDE02022-Access control 2-Comfort opening   adapted to=> "active"
Ch: IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen   adapted to=> "active"
Ch: IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen adapted to=> "active"
Ch: IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen   adapted to=> "active"
Ch: IDE08542-ENG116651-Access control 2-Funk Komfort schliessen   adapted to=> "active"
Ch: IDE08542-ENG115670-Access control 2-Komfortbedienung global   adapted to=> "active"
Ch: IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar adapted to=> "adjustable"
Kontak anahtarını kapatınca/çıkarınca camı açma/kapama.
Ch: IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus adapted to=> "active"
Ch: IDE08542-ENG116649-Access control 2-Freigabenachlauf FH bei Tueroeffnen adapted to=> "not active" (Bu active olursa kapıyı açınca cam açılmıyor)
Ch: IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen
Ch: IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen adapted to=> "active"
Sis farlarının *KÖŞE DÖNÜŞ FARI* olarak kullanılması için gerekli adaptasyon ayarı aşağıdaki gibidir.
Geri vitese takınca iki sis birden yanıyor ve siz park ederken etrafı aydınlatıyor.
1. 09-Cent. Elect.
3. Adaptation-10
Ch: ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12 - " Abbiegelicht links "
Ch: ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13 - " Abbiegelicht rechts "
***Sis farının yanması için Viraja girilen max hızı belirleme. (Normal değeri 40.0 km/h)
Ch: IDE03638-ENG116676-static AFS light-Upper speed threshold
Stored value 60.0 km/h
C/H L/H de normal far ile birlikte sislerin de yanması.
ch.IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten
--->adapted from => "Low beam" to=> "Fog light"
***Farları iptal edip sadece sis farları için:
Ch: ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6 - 'not active'
Ch: ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7 - 'not active'
***Sis Farları ile birlikte Yan ayna sinyalleri de yanması.
Ch: ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16 - 'ComingHome LeavingHome'
Ch: ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17 - 'ComingHome LeavingHome'
Selektörlerde Sislerin Yanması.
09-Central Electric
16-Security Acces:31347
10-Adaptation
Ch: ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12 adapted from 'not active' to 'Headlamp flasher'
Ch: ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12 adapted from '0' to '100'
Ch: ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13 adapted from 'not active' to 'Headlamp flasher'
Ch: ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13 adapted from '0' to '100'
Bagaj Kapağı açıldığında Yan ayna sinyallerinin yanması.
Ch: ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16 -'0-50-100' arasında ışık şiddeti değeri
Ch: ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16 - 'Rear lid open'
Ch: ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17 -'0-50-100' arasında ışık şiddeti değeri
Ch: ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17 - 'Rear lid open'
************************AMERİKAN PARK*********************
1. 09-Central electric
3. Adaptation-10
***Ön Sinyallerde Amerikan Park için***
Ch: ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0   adapted from 'not active' to 'Parking light'
Ch: ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1   adapted from 'not active' to 'Parking light'
Ch: ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0 adapted from '0' to '25' (Zayıf yanarsa 50 yapın)
Ch: ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1 adapted from '0' to '25' (Zayıf yanarsa 50 yapın)
***Yan Ayna Sinyallerinde Amerikan Park için***
Ch: ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16 adapted from 'not active' to 'Parking light'
Ch: ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17 adapted from 'not active' to 'Parking light'
Ch: ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16 adapted from '0' to '25' (Zayıf yanarsa 50 yapın)
Ch: ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17 adapted from '0' to '25' (Zayıf yanarsa 50 yapın)
Arka Sinyaller ile Arka Parkların Çakarlı yanması.
09-Central Electric
10-Adaptation
Ch: ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23   adapted from 'not active' to 'Blinken links Dunkelphase'
Ch: ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24   adapted from 'not active' to 'Blinken rechts Dunkelphase'
Ch: ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24   adapted from '0' to '100'
Ch: ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23   adapted from '0' to '100'
Ön Sinyal ile Yan Ayna Sinyallerinin Çakarlı yanması.
Ch: ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16   adapted from 'Blinken links Hellphase' to 'Blinken links Dunkelphase'
Ch: ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17 adapted from 'Blinken rechts Hellphase' to 'Blinken rechts Dunkelphase'
PLAKA ARIZA IŞIĞI SÖNDÜRME.
1. 09-Cent. Elect.
3. Adaptation-10
ch.ENG124885-ENG115437-Leuchte 25kzl-HA60 TYPE_OF_LOAD_25 - 'allgemeineLEDmit open load diagnose'
IŞIK SENSÖRÜ HASSASİYETİNİ AYARLAMAK.
1. 09-Cent. Elect.
3. Adaptation-10
ch.IDE08786-
-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit adapted to=> "sensitive"
-ENG11105-Assistance light functions-Assistance_lighting_sensitivity_adjustable   adapted to=> "present"
-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent   adapted to=> "present"
-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung adapted to=> "present"
-ENG116636-Assistance light functions-Notbremsanzeige NBA   adapted to=> "active"
Multimedia ekrana ESC menü öğelerinin eklenmesi (düğmedeki ASR / ESC gezi seçeneklerinin değiştirilmesi): ESC-sport, ESC-off:
-03 ABS Brakes → Security Accees 40168 → Long coding helper
Byte 16 – bit 4 ve bit 5
Offroad göstergesi
5f kanalı adaptation
Car function adaptations gen2 menu display compass: active
Car function adaptations gen2 menu display compass over thres : acvtive
Car function list BAP gen2 compass 0x15: active
Çevrimdışı resolute
    • İleti: 90
Hiç kullanan var mı?
15 km üzeri kapıların otomatik kilitlenmesi güzel olabilir.
Çevrimdışı mrt03mrt03
    • İleti: 851
Alıntı yapılan: resolute;550117
Otomatik kilitleniyor zaten.
Çevrimdışı resolute
    • İleti: 90
Alıntı yapılan: mrt03mrt03;550170
Tüm rapidlerde otomatik kilitleniyor mu?
Çevrimdışı Managerhtd
    • İleti: 36
Bende otomatik olarak kilitliyor 15 km hıza ulaşınca.
Çevrimdışı resolute
    • İleti: 90
Alıntı yapılan: Managerhtd;550174
Hangi yıl aracınız?
    • İleti: 851
2015 bendeki servis güncelleme yapması lazım
Çevrimdışı resolute
    • İleti: 90
Alıntı yapılan: mrt03mrt03;550185
Bendeki 2014 ve otomatik kilitlemiyor.
Servise gidince ona da baksınlar.
Teşekkürler bilgi için.
    • İleti: 851
Alıntı yapılan: resolute;550186
Yeni yazılım geldi sanırım 22 haftada. Bildiğim kadarıyla.
Çevrimdışı resolute
    • İleti: 90
Yazılımlarla ilgili bir forum yada sayfa var mı, sürümler hakkında bilgi alabileceğimiz.
Çevrimdışı resolute
    • İleti: 90
OBD2 portunu kullanarak bu uygulama aşağıdaki seçenekleri değiştirmeye imkan sağlıyor. En azından geliştiricinin iddiası böyle.
Var mı deneyen ve de garantiyi bozar mı?
http://www.caristaapp.com/customizations/?car=skoda_rapid_2012
Çevrimdışı **SEMİH**
    • İleti: 1522
Alıntı yapılan: resolute;550403
denediniz mi hocam bu arada odb2 cihazımı okutamadım bu araçta. fabia2 de okuyordu.
Çevrimdışı tatar331
    • İleti: 102
Alıntı yapılan: 09fabia;560009
bende okutamadım 2014 rapid..görmedi...(elm327 mini ınterface OBDII)
Çevrimdışı Balasagun
    • İleti: 56
    • https://www.facebook.com/sadayrapid/
Nasıl görmez yahu, ben de elm327 wifi var obd2 portuna takıyorum, torque, dashcommand ve carista (apple) hepsini çalıştırıyor.
yalnız programı satın alıp pro versiyonuna geçmezseniz aktif /deaktif yapma olayı yapılamıyor, sadece görüntülemiş oluyorsunuz, bir de şunu söyleyeyim, vagcom da açılan özellik menülerinin yarısı ancak var bunda.
« Son Düzenleme: 18 Şubat 2016, 17:32:25 Gönderen: Balasagun »
Çevrimdışı tatar331
    • İleti: 102
Alıntı yapılan: Balasagun;560630
birşeyler yükleniyor diyor ama bekle bekle bekle sonu yok...
