Şanzımana operasyon
http://www.crustyquinns.com/tech/gears.html
Devamı bu linkte..
             Power enters from the clutch onto the countershaft and leaves             via one of the gear ratios out the sproket. "X" means this cog             idles; ie is able to free spin. Cogs are numbered.                                         Power Flow.
           Mumbo from the engine hits the gearbox via the clutch and spins the           countershaft. You can see there are 5 cogs on the countershaft and           these correspond to cogs on the mainshaft, each of the cog pairs           produces a different ratio. This box is... yeah okay, you guessed it,           a 5 speed ;)
            The "X" crosses mean the cog can free spin. At the moment in fact,           the gearbox is in neutral. You'll notice for every cog that can free           spin it's mate cannot - it is locked to the shaft. It can move           backwards and forwards, but it always spins with the shaft it is           attached to.
                                 Selection.
           From the first photo you can see firstly how a cog is locked to it's           shaft but can move from side to side - it is splined. Are ya with me?           A shows the lumps on the shaft and B shows the inverted lumps in the           cog.
            C which we shall call a "locker" for want of a better term           performs the selection of a gear. This mechanism is shown better in           the next photo...
             A cog with it's (B) spline connection and (C) "lockers".
                                 Lumps and holes... when a gear that is locked to the shaft gets told           to "swing left" or "swing right" as the case may be, the locker mates           with it's next door neighbour cog. By an amazing coincidence, that           cog is normally and idler, but once joined it too is locked to the           shaft and therefore must spin with the shaft.
            This how gears are selected - the rider essentially starts moving           the cog across to it's next door neighbour. When the locker lines up           with the corresponding hole, in she clunks.
             A cog and it's neighbour - with (B) spline connection and (C)             "lockers".
bu arada 1000 tlye  1.4 TDI lere 6. vites yapılıyomuş(konuyu baltalamak gibi olmasın şanzıman diyince aklıma geldi:))
Alıntı yapılan: dgn;70618
Dümdüz 6. vitesin çakılması kanımca hiç hoş olmaz, o 1000 TL ye kasım kasım gülerim, tüm oranların baştan düzenlenmesi lazım :D
Çevrimdışı Symbol
  • M U L T I J E T
    • İleti: 587
6. vites yerine TDI'a chip yapılsa çok daha ekonomik bir araç olur bence ;)
Alıntı yapılan: Symbol;70650
Ya o olay derin abi. Valla çok derin.
Çevrimdışı Symbol
  • M U L T I J E T
    • İleti: 587
Alıntı yapılan: Symbol;70657
Derin derken ?
Daha ekonomik derken şimdi bu iş karışık abi.
Bu olayla aslında düşük devirlerde daha fazla doluluk elde ediliyor, bunun için çok turbo devri lazım ve buda daha fazla yakıt+havadan geçiyor. Şimdi düşük devirde bana biraz daha fazla yakıtla baygınlıktan kurtaracaksa, benim üst devir gezintimden dahada ekonomik olacaksa OK. Ama en fazla ne kadar ekonomik olabilir?
Yani anlatmak istediğim bu olay motordan ziyade turboya biraz daha görev biçiyor, hortum çıkaran falan çok, zebilnen. Kara duman olmazsa olmazımız, e orjinalliğide gidecek cihazın, ben takmasamda 2.el olayında dert.
Bu olayın uygulama maliyeti bana km başına ettirdiği 1-2 kuruşu çıkaracak mı?
Chip var diye asılıp durucam, sınırları genişletilmiş motoru bir de öyle ben mahvedeceğim, eeee 1.6 düz benzinlilere ayar atar bi hale gelir 240 tork-105 bg ile çok rahat. Mini bi dizelden ayar çekmekde piyasaya hoş olacaktır, e yapmaman lazım ama dicen, e madem yapmayacam niye motorun işletimini bozdum, 500 devir yukarda sür yine ekonomik, 4.5 litre şehir içimi 3.9 ortalamaya çekecek halie yok, e başta dedim uygulama maliyeti.
Offf kararsızlık... Turbo kucaklarsam kendimi asla affetmem.
