Fabia,roomster kapı kolunu sökmek
Tercümeye gerek yok sanırım.Fotoğraflar gayet açıklayıcı..:ok:
Step 1.
Your common garden exterior door handle in all its glory.
Resized to 75% (was 800 x 600) - Click image to enlarge
Step2.
On the edge of the door you have two grommets (Fabia) or one (Octavia). Take the top one out and loosen the T20 torx screw inside a few turns (dont take out).
Step3.
Now take the bottom one out. Inside here is another T20 screw. Its fairly recessed so you will need a fairly long narrow screwdriver. Take the handle in and and hold it in the open position slightly. Now undo the screw gently until you feel a small resistance, stop there. If you have wound it out the handle should hold in the open position.
Now with the handle in its locked position lever the lock cylinder out with a suitable trim lever so as not to damage the paint work. They are usually quite welll seated but it its not moving at all undo the top T20 screw a little bit more.
With the cylinder out you can no see the bowden cable that connects the handle to the lock mech inside the door. Make a mental note of the position of the cable in its channel or even better dob a little bit of paint or tippex on the end.
Pop the cable off
Now slide the whole handle backwards a touch
And the handle swings out
Withdraw the handle and your done. The lock cover just pops off.
Kaynak : briskoda
Yarın Hakan bunun direk uygulaması yapar hatta fityoya bile çeker yayınlar :hanz:
Evet söz şimdi Hakan'da :hanz:
Bunları soran olmazsa anlatmaya bile gerek yok, kardeşime söktürüyom ben :++: :++: :++:
Çevrimdışı mustisahin
  • T U R B O T
    • İleti: 6509
:)sök sök sen, ondan sonra arabanın orasından burasından gacur gucur sesler gelirse görürsün:)
octaviaman
Alıntı yapılan: mustisahin;73571
:+1:
Söküp takmaya gelmez durduk yerde.Ama Böyle gördükçe Beni de dürtüyor.Koymayın şunları böle ya:hanz:
Sökmesi basitmi diye bakmak için kendimi zor tutuyorum :D
nası söktüğünü anladım ama niye söktüğüne bi anlam veremedim:D
