mazda 3 1,6 dizel
arkadaşlar 1,6 dizel mazda 3 ler gelmeye başlamış. teknik verileri güzel ancak düşük donanımla geliyor ve fiyatı yüksek geldi bana.
http://www.mazda-tr.com/showroom/mazda3/specs/
    • İleti: 15590
Ya ben bu mazda3'lerin mavilerine hasta oluyorum :) Burda bir bayanda var bir tane.Ne zaman şirketin önünden geçse dikkatimi çekiyor.Satarsa alırım ha :++:
Çevrimdışı yuksel_1987
    • İleti: 16
fiyat bence sinek avlatıcı olmuş bu fiyata golf dizel alırım.
Alıntı yapılan: yuksel_1987;75202
:ok::+1::rock1:
Dizel en hızlı :D
Bana PSA motoru gibi geldi :)
Çevrimdışı isikayhan
  • SIMPLY CLEVER
    • İleti: 1374
Alıntı yapılan: hakanerdogan;75230
Dizel en hızlı :D
Ford ile PSA ortak dizel motor ürettiğine göre :)
http://en.wikipedia.org/wiki/Mazda_Diesel_engine#Y6
Y6
Mazda Y6 engine (called 1.6 MZ-CD or 1.6 CiTD) is rebadged PSA DV6 engine, produced in PSA engine plant in Trémery or Ford engine plant in Dagenham. These 1560 ccm DOHC 16-valve turbo diesel engines with bore 75.0 mm, stroke 88.3 mm and compression ratio 18.3:1 are shipped to Hiroshima and mounted into Mazda 3 Axela and Mazda 2 DE in three versions together with 5-speed manual (Getrag-Ford developed, J65M-R) or 4-speed automatic "Activematic" transmission:
  • 66 kW (90 PS; 89 hp) at 4000 rpm, 215 N·m (159 lb·ft) Nm at 1750 rpm
  • 66 kW (90 PS; 89 hp) at 4000 rpm, 205 N·m (151 lb·ft) Nm at 2000 rpm mounted in Mazda 2 DE
  • 81 kW (110 PS; 109 hp) at 4000 rpm, 240 N·m (180 lb·ft) Nm at 1750 rpm
Engine features:
  • DOHC belt-driven
  • aluminium cylinder block with cast iron liners
  • dual-mass flywheel
  • second generation Bosch common rail injection system with pilot injection phase and 1600 bar pressure
  • 6-hole injectors
  • Bosch EDC16 powertrain control module
  • drive by wire accelerator pedal
  • Garrett GT15 (VNT15) turbocharger
  • large front mount intercooler (larger than 2.0 MZR-CD)
  • Euro Stage III emission rating (Euro Stage IV with DPF system, catalytic additive in separate 1.8 L tank, refreshed every 60000 km)
Bilgi paylaştıkça çoğalır.
M.Niyazi Saral
Valla 1.6 TDCI motoru ne motormuş arkadaş, yoldan geçen adamada takacaklar :D :D :D
efe_38
ben bugün okuldan gelirken gördüm park halindeydi,gözümü alamadım o kadar şık duruyor :ok: mazda sağlamdır verilen paranın hakkını verir :)
Alıntı yapılan: hakanerdogan;75259
valla 1.6 tdci motoru ne motormuş arkadaş, yoldan geçen adamada takacaklar :d :d :d
Çevrimdışı SEAHAWK
    • İleti: 1210
:++::++::++: Çok iyiydi.:ok::++::++::++:
Ayrıca,
Elbette iyi; boşuna mı açtık başlığını:wnk:
http://www.skodaturkey.com/showthread.php?t=2804
« Son Düzenleme: 23 Şubat 2010, 23:47:14 Gönderen: SEAHAWK »
SEAT CORDOBA 1.4 TDI 80HP
Abi baktımda artık 5 üzerinden 2 yıldızda bi tecrübe var artık bu avtmabil sektörel bilgimde :D :D
