Haynes’ in Skoda Tamir Ve Bakım Kitabından Skoda Favorit/Forman 135 Ve 136’ nın Tekni
Ziyaretçi · 6 · 29770
Haynes’ in Skoda Tamir Ve Bakım Kitabından Skoda Favorit/Forman 135 Ve 136’ nın Teknik Verileri Ve Diğer Bazı Değerleri
SKODA Favorit/Foreman 135/136 CAT
1992 to 1996
Notes and Illustrations
1289 cm3 1289 cm3
Engine and cooling system
Type 135/136 OHV 40/50kW
Capacity (cm3) / number of cylinders 1289 / 4
Compression ratio / pressure bar 135: 8.8. 136: 9.5 / _
Oil pressure bar [4.1 to 5.5]
Oil temperature ºC 70
Valve clearance - inlet mm 0.20. Alloy: 0.25
Valve clearance - exhaust mm 0.20
Firing order 1-3-4-2
No 1 cylinder position TCE
Thermostat opening temperature ºC 88 to 103
Radiator cap pressure bar 1.00
Fuel system
Idle speed - manual [auto] rpm 900 to 950. 136: 750 to 850
Fast idle speed - manual [auto] rpm _
CO @ idle speed [3000 rpm] - see page VI % 0.15
HC @ idle speed [3000 rpm] - see page VI ppm 80
CO2 @ idle speed [3000 rpm] - see page VI % _
Carburettor / fuel injection Bosch
Type / ref Mono-Motronic
Main jet / needle _
Injection pressure bar 0.75
Pump pressure bar _
Octane rating RON 95
Ignition system
Type Motronic
Ignition coil Renix 5100 620005
Primary resistance ohms _
Ballast resistor ohms _
Voltage - Tmnl 15(+) to earth V _
Distributor _
Points gap (air gap) mm _
Dwell angle º (%) _
Condenser capacity µF _
Rotation Clockwise
Ignition timing - basic [static º Crankshaft @ rpm 14 BTDC @ 900
V = Vacuum NV = No Vacuum _
Total ignition advance
º Crankshaft @ rpm
º Crankshaft @ rpm
º Crankshaft @ rpm
40 @ 4500
_
_
Centrifugal check. º Crankshaft @ rpm
º Crankshaft @ rpm
º Crankshaft @ rpm Computer control
_
_
Vacuum range check mbar Computer control
Spark plugs Champion
Type RC12YC
Electrode gap mm 0.60 to 0.90
Electrical system
Battery V / CC / RC 12 / 42Ah
Alternator voltage / full load current / engine rpm 14.0 / 55 / 3000
Starter motor current / voltage - cranking A / V 150 to 210 / 9.5
Starter motor current / voltage - locked A / V 340 / 8.0
Running gear
Brakes -
Front (min. friction material thickness) mm 8.0
Rear (min. friction material thickness) mm 1.0
Tyres
Saloon Size 165/70x13
Estate / Van Size 165/70x13
Pressure - front / rear - Saloon bar 1.9 / 1.8
Pressure - front / rear - Estate / Van bar 1.9 / 1.8
Front suspension / wheel alignment
Toe-in (+) / Toe-out (–) mm [º] +1.0±1.0
Camber +20’±30’
Castor +1°30’±45’
King pin inclination _
Rear suspension / wheel alignment
Toe-in (+) / Toe-out (–) mm [º] +1.2±1.4
Camber -1°24’±30’
Torque wrench settings
Cylinder head - stage 1 Nm BOLTS: 17 to 20
Cylinder head - stage 2 Nm + 90°
Cylinder head - stage 3 Nm + 90°
Cylinder head - stage 4 Nm NUTS: 20 to 26
Big-end bearings Nm 36 to 40
Main bearings Nm 60mm pin:50 to 551
Clutch cover Nm 23 to 28
Flywheel [driveplate] Nm 55 to 65
Front hubs Nm 240 to 270
Rear hubs Nm WSM
Wheel nuts / bolts Nm 60 to 70
Spark plugs Nm 20 to 302
Capacities
Engine oil & filter litres 4.5
Gearbox - 4-speed [5-speed] litres 2.4
Automatic transmission - refill litres _
Final drive litres WT
Cooling system litres 6.1
Fuel tank litres 42
ugur abi senin arabayı anlatıyor yani.bütün detayını ögrenmiş olduk sayende teşekkürler
Çevrimdışı enisekiz
    • İleti: 6
Haynes Bakım Kitabını indirmek istiyorum ama linkler hep eski ve silinmişler, varsa  paylaşabilir misiniz?
Çevrimdışı metearslan
    • İleti: 7
