o 2,0 lar amerikan pazarında kullanılan 8v motorlar sanırım.
2.0 MPI Avrupa'da da kullanılımış gibi görünüyor
Octavia I'de varmış
http://en.wikipedia.org/wiki/%C5%A0koda_Octavia#Engines http://en.wikipedia.org/wiki/List_of_Volkswagen_Group_petrol_engines#2.0_R4_37-88kW2.0 R4 37-88kW
identification
parts code prefix:
engine displacement & engine configuration
1,984 cubic centimetres (121.1 cu in) inline-four engine (R4/I4); bore x stroke: 82.5 by 92.8 millimetres (3.25 in × 3.65 in), stroke ratio: 0.89:1 - undersquare/long-stroke, 496.1 cc per cylinder, compression ratio: 10.0-10.5:1
cylinder block & crankcase
CG25 grey cast iron; five main bearings; die-forged steel crankshaft, forged steel connecting rods
cylinder head & valvetrain
cast aluminium alloy; two valves per cylinder, 8 valves total, hydraulic bucket tappets, timing belt-driven one-piece cast single overhead camshaft (SOHC)
aspiration
cast aluminium alloy intake manifold
engine management
Bosch Motronic or Siemens Simos electronic engine control unit (ECU)
EWG-rated motive power & torque outputs, application, ID codes
37 kilowatts (50 PS; 50 bhp) @ 2,800 rpm; 140 newton metres (103 ft·lbf) @ 2,100-2,400 rpm — Volkswagen Industrial Motor multi-fuel (petrol / LPG / CNG) - CBS (08/06->)
43 kilowatts (58 PS; 58 bhp) @ 2,800 rpm; 143 newton metres (105 ft·lbf) @ 2,100-2,400 rpm — Volkswagen Industrial Motor multi-fuel (petrol / LPG / CNG) - BEF (04/02->)
DIN-rated motive power & torque outputs, ID codes
80 kilowatts (109 PS; 107 bhp) @ 5,400 rpm; 160 newton metres (118 ft·lbf) @ 3,500 rpm — Ecofuel (bivalent) (CNG) Touran, Caddy, Transporter/Caravelle - BSX
85 kilowatts (116 PS; 114 bhp) @ 5,400 rpm; 165 newton metres (122 ft·lbf) @ 3,200 rpm — AWG, AWF
85 kilowatts (116 PS; 114 bhp) @ 5,400 rpm; 166 newton metres (122 ft·lbf) @ 2,600 rpm — AGG
85 kilowatts (116 PS; 114 bhp) @ 5,400 rpm; 166 newton metres (122 ft·lbf) @ 3,200 rpm — 2E, ADY, ABA
85 kilowatts (116 PS; 114 bhp) @ 5,200 rpm; 170 newton metres (125 ft·lbf) @ 2,400 rpm — APK, AQY
85 kilowatts (116 PS; 114 bhp) @ 5,200 rpm; 170 newton metres (125 ft·lbf) @ 2,600 rpm — ATM
85 kilowatts (116 PS; 114 bhp) @ 5,400 rpm; 172 newton metres (127 ft·lbf) @ 3,200 rpm — AZH, AZJ
85 kilowatts (116 PS; 114 bhp) @ 5,400 rpm; 172 newton metres (127 ft·lbf) @ 3,500 rpm — AZM
88 kilowatts (120 PS; 118 bhp) @ 5,600 rpm; 174 newton metres (128 ft·lbf) @ 2,400 rpm — ATF
88 kilowatts (120 PS; 118 bhp) @ 5,600 rpm; 175 newton metres (129 ft·lbf) @ 2,600 rpm — AUZ, ASU, AVA
applications
SEAT Ibiza Mk2 & Mk3, SEAT Córdoba, SEAT Toledo Mk1, SEAT Alhambra, Škoda Fabia Mk1 (6Y), Škoda Octavia Mk1 (1U), Škoda Superb Mk1 (3U), Volkswagen Polo Mk4, Volkswagen Golf Mk3, Volkswagen Golf Mk4, Volkswagen Vento, Volkswagen Bora, Volkswagen Jetta, Volkswagen New Beetle, VW Passat B3, VW Passat B4, VW Passat B5, Volkswagen Industrial Motor
